Dale(MO)
06-18-2004 11:32:58
Re: Case 450B - more questions in reply to David in SC, 06-18-2004 10:06:07
David, I own an HD3 Allis Chalmers that was in about the same boat. I was lucky, it had a pretty good undercarriage - I had to put roller seals in it, and re-pin and re-bush a couple of them - but all the iron was in good shape. The motor, on the other hand, has been a different story. Like yours, it burned about 2 quarts of oil every hour, and it had surges of power - sometimes it had good power, other times it fell on its face. I ran it some (graded my yard, cleared some brush, etc.), but the oil cost and the aggravation was large, so I decided to rebuild it this past winter. I can't say I did it any harm running it, but I didn't do it any good, either. I have rebuilt or replaced EVERY moving part in the motor except the cam shaft, and have put about $2000.00 in it, but it runs really well. I think it was money well spent. I'll find out shortly, after I get done painting it and putting it back together. If the undercarriage is not completely worn out - the tracks don't fall off, and the rollers don't wobble around - I would put my money into the motor for now. The undercarriage can be taken care of later. With the motor in the shape it's in, you could easily scramble it, and then you will be looking for a complete one. Good luck!
