Dear Bob, You will need to break the track in order to pull the final. Your access to the steering clutches is very limited on the D-2. With the exception of adjustments and lubrication, the access holes won't let you service much else. Pulling the final is not all that bad, as long as you are on a good concrete floor and have a couple of floor jacks and some blocking, or an overhead crane. The track pins you have are the early style. The bolt holes are actually puller holes for the two tapered pins that are inside the track pin itself. If you look carefully, you will see the O.D. of the tapered pins. Find several flat washers that are slightly larger than the O.D. of the tapered pin, stack them up and use the bolt as a puller bolt. If they don't come easily, use a little heat. Pull both tapered pins (inside and outside), then remove the split rings and drive the master pin out. Again, if it doesn't drive easily, use a little heat. Be sure to leave the track pad/bolts in place, or you may spread the link when driving the master pin out. The little tapered pins actually "swell" the master pin slightly to keep it in place. Once removed, the master pin will come out much easier. If things don't go well and you have to burn the master pin out, don't worry. I am quite sure replacements are still available and are reasonably priced. The new master pin will not have the little tapered pins, just the split rings. If you do use them, be sure to install them with the "dimple" in the center of the pin facing out, so you can easily locate the master pin the next time you want to do a little track work. I hope this is helpful. If you have any other questions and would prefer to talk about it, feel free to give me a call. I can be reached at (860) 738-2441. Keep in mind that I live in the People's Republic of Connecticut, several time zones from you. Good luck! Scott
