JD 350 diesel timing
dave in vermont
06-21-2004 13:44:17
I want to remove the injection pump to have it serviced and need to turn the engine over to align the timing mark and TDC.
The service book says to "bar" the engine. How do you bar the engine?
The only thing I can think of is to remove the starter to gain access to the ring gear and then use a bar on the gear teeth.
There must be an easier way?
Any ideas from you will be much appreciated.
bob
06-21-2004 21:29:43
 Re: JD 350 diesel timing in reply to dave in vermont, 06-21-2004 13:44:17
the side opposite from the starter. The timing cover. Unbolt it & flywheel gears are exposed. Bar it until timing hole lines up. Where is your service manual?
