JD2010 Clutch Setup
Paul Sinnis
06-22-2004 17:07:34
I am assembling the steering clutch and was wondering how much compression there should be on the pressure plate. When I set the pressure plate in place before bolting it down there is almost no clearance under it. Only about 1/8" gap before tightening bolts. This doesn't seem to put much preload on the discs. Anyone have any idea how much gap (or preload) there should be?
83Jim
06-23-2004 05:44:15
 Re: JD2010 Clutch Setup in reply to Paul Sinnis, 06-22-2004 17:07:34
Paul,
There should be adjusting screws (probably 3) on the pressure plate which contact the levers that the throw out bearing actuates.
On my JD 350, you loosen the lock-nuts on these screws and then turn them until you get a precise clearance underneath the area of the lever that the throw out bearing runs on/actuates.
There is a tool which gauges this dimension and I have the pattern for one on my 350 but not the 2010.
Hopefully, some one on this website will have the tool or measurement that you need.
Good luck.
