Shuttle problems 1974 CK backhoe
Wyman
06-24-2004 09:55:44
My 1974 CK back hoe shuttle jumps out of the forward gear when it is not under a load. It is a mechanical shuttle. I have removed the cover once and had to replace a bolt that was broken off from trying to shove it further in to the forward position. Reverse works fine and it does not seem to be a linkage problem. any help would be appreciated.
simon
06-24-2004 17:06:13
 Re: Shuttle problems 1974 CK backhoe in reply to Wyman, 06-24-2004 09:55:44
It sound like your shifting gear are used to much the edge of the gear are wore to much so you have to replace the gears
