TD24 starting procedure
Mike P
06-24-2004 19:46:29
HELP .. I have been given a td24 cable blade dozer,it last ran 15 years ago, apparently there was nothing wrong with it. can someone tell me if it is 6 or 12 volt ,neg or pos ground,and the procedure for starting.
Kelly
06-25-2004 18:26:56
 Re: TD24 starting procedure in reply to Mike P, 06-24-2004 19:46:29
Mike P,
The early TD-24 tractors are equipped with a 24-volt cranking system and a 12-Volt ignition and if equipped with lighting system. Later model TD-24 tractors and all TD-25 tractors are equipped with a straight 24-volt system.
Bob/Ont
06-24-2004 21:52:07
Mike, look at the voltage regulator it should have a # for voltage and an N or P for the groung. In warm weather they can start up direct on diesel but there is a lever to put them on low compression for gasoline start. I forget a lot about them butyou will know which way to put it when you start cranking.
Later Bob
