Axle Nut Case 350
Windancer
06-26-2004 02:22:03
Anyone out there want to contribute
and advice on how (which tool to use)
to tighen up the large nut that holds
the rear sprocket on a Case 350 dozer.
Torque amount? Mine is loose. Thanks
Joe
06-28-2004 19:24:29
 Re: Axle Nut Case 350 in reply to Windancer, 06-26-2004 02:22:03
Is the sprocket loose on the axel shaft,if so it will be hard to hold the nut,we have taken larger cotter pins and sawed them in two and tapped them in the spaces between the two splines,then locktight the nut on----- Joe
Taylor Marret
06-27-2004 19:42:19
Cut a piece of 1/4 plate or bigger to match the nut.
