Does anyone have a chain and sprocket coupler?
Mark
06-30-2004 05:51:25
third party image
I am looking for the chain and sprocket coupler that goes on a LaPlant-Choate hydraulic pump on the front of a Caterpillar D4. It looks like this if I can get the picture to work.
Thanks.
Mark
07-01-2004 09:38:47
 Re: Does anyone have a chain and sprocket coupler? in reply to Mark, 06-30-2004 05:51:25
I believe you guys are right about the weld on sprocket. I will have to spend some time at that URL, it looks very interesting.
Ol Chief
07-01-2004 12:13:44
 Re: Re: Does anyone have a chain and sprocket coup in reply to Mark, 07-01-2004 09:38:47
Check with Boston Gear co. on the net then call them.They probably have those sprokets and will possibly brooch the keyway and splines for you.
Wayne
06-30-2004 21:14:08
Like the other post said you should be able to have the old sprocket cut off the hub and a new one welded on. I know places like Grainger, and MSC usually carry weld on sprockets. If not check with your local bearing house and see what they can get you from Martin or one of the other manufacturers.
Bruce Boyd
06-30-2004 10:00:13
Mark,
I can't help you with those parts but if you can't find them you might be able to have the old sprokets cut off the hubs and new ones welded on. Know anyone with a lathe? Try this site for parts.
Link
Bruce
