john deere 1010 w/ loader and backhoe
tim
07-02-2004 18:56:25
i'm looking at a 1010 w/ loader and backhoe what would be a fair price if every thing is in good shape little rusty but all in all not to bad any body have any coments on this tractor
JDknut
07-08-2004 04:04:01
 Re: john deere 1010 w/ loader and backhoe in reply to tim, 07-02-2004 18:56:25
It would be better if it were a gasser. The Diesels had some durability problems related to the infamous "sleeve and deck" cylinder configuration used in the 1010/2010 series. The greater vibrations from the Diesel caused liner seal failures. The gassers held up better. Some engine parts are harder to find on these than on the others, too. Price, maybe $5-$6K depending on condition and whether gas or Diesel. Good luck
Jim
07-07-2004 13:23:02
My 1010 crawler is a 1963 and has a scarfier ripper on the back which mounts to the same area as the back hoes mounts. In my opinion, this machine is not built heavy enough for the abuse a back hoe can hand out. I also have a 350-B crawler/loader with a model #9300 hoe on the back. This set up works pretty well, but the frame/finals are built some what beefier then the 1010. I would look very closely for cracks in the castings in the mounting area. Just because the finals aren't leaking doesn't mean there isn't a structural crack that will soon be costing you some big bucks. Also, take it for a little cruise and check out how rear end heavy it is. Go up a slight incline, stop and lock the brake and be sure it is stationary with front bucket & hoe off the ground slightly. Dismount, and stand back a ways so you can see the angle the entire machine is setting at. You will see the finals/sprocket are taking all the weight, in there lies the problem. Back hoes are just flat out "tough" on crawlers. My two cents.
