IH 250C tackloader
JoeinTX
07-05-2004 00:28:29
I'm looking for undercarriage parts for the International 250 trackloader-in particular pads. I don't need anything nearly new but just decent, 50% or so life stuff. Not much turns up when I "Google" search for this machine, so I'm wondering if any of you fellas know where to go. Also, I would think that TD-20 u.c. parts might work on this beast if I had to use them-yes or no, gurus...??? Thank you in advance....
Heat Houser
07-05-2004 20:45:44
 Re: IH 250C tackloader in reply to JoeinTX, 07-05-2004 00:28:29
TD20C pads have the same bolt pattern however, there were two styles. The early shoe bolt pattern was rectangular and the later was wider at the front two bolts than the rear. You will need to cut the TD20 shoes down to 18 inches wide or they will contact the loader frame. Good luck.
