JCB 3C II Backhoe Cyl Head Gasket
G Man
07-05-2004 05:56:12
Hi all
Just renewing the Cyl head gasket on my Leyland/Nuffield/BMC (depending on who you talk to) engined JCB.
Does anyone have the torque levels to reach on the studs when replacing and if there is any requirement for further torquing when engine is run and warmed up.
All help appreciated
G from Ireland
snowbound
08-10-2004 13:28:26
 Re: JCB 3C II Backhoe Cyl Head Gasket in reply to G Man, 07-05-2004 05:56:12
I'm also changing the head gasket on a 3d mark III. It has the 3.77 engine and a lot of hours.Dealer was unable to find the torque specs for the head. How did 80 ft/lbs work for your's? Only book I have is the operator's manual for the 3c & 3d mark III (wiring schematics included)
AJ
07-06-2004 11:25:52
On the 3.8 engine if I remember correctly the head nuts torque was 80 ft/lbs,go over them in an X pattern starting with centre one and working out to each end,do them three times,I did not retighten any I done and had no bother.
AJ
G Man
07-07-2004 00:55:54
 Re: Re: JCB 3C II Backhoe Cyl Head Gasket in reply to AJ, 07-06-2004 11:25:52
Thanks for your help AJ
Much appreciated
G
