International TD 9 stuck on high compression
Jerry Walters
07-06-2004 14:09:58
I have an International TD 9 stuck on high compression. When I try to start the tractor, I move the starting lever for low compression, the compression lever rotates a cam on the manifold side of the tractor but the tractor is still in high compression. Any tips on how to get the high compression released or if not, can it be started on deisel some way?
king of obsolete
07-08-2004 05:43:56
 Re: International TD 9 stuck on high compression in reply to Jerry Walters, 07-06-2004 14:09:58
head over to redpower, we can post pictures there, thanks
RO
07-07-2004 18:55:35
Once on my TD-18, I found that a small linkage segment which opens the "gas" chamber valves had become dislocated. I found it by removing the valve cover and then it was obvious.
This might be your problem also.
