JD350 dozer /gas
LOYAL
07-09-2004 13:47:48
Was running fine and then quit, will not turn over, replaced starter, have good battery and good connections. Hydraulic pump is not stuck, any idea what I should do next??? (Engine trouble or transmission trouble??) Need help, where can I find parts? Thanks Loyal
Jonathan
07-09-2004 16:22:21
 Re: JD350 dozer /gas in reply to LOYAL, 07-09-2004 13:47:48
If it has a reverser, there is an "isolator" assembly comprised of an internally splined disc supported around its circumference by springs...These springs break with age and tend to get stuck between the flywheel and the clutch housing. If this is the case...You have to remove the engine to repair...if you remove the starter and pry the flywheel ring gear with a bar...while fishing around in there with a magnet, you can prove this as the problem by finding pieces and seeing marks on the flywheel..
jdemaris
07-12-2004 20:27:35
 Re: Re: JD350 dozer /gas in reply to Jonathan, 07-09-2004 16:22:21
Sounds right except most of the early 350s don't have the torsional isolators - they use a spring-dampened disk like the 1010s had. But, we don't know if it's an early 350, or a B, or what.
