Hydraulic pump for TD-9
Carl Matson
07-09-2004 14:50:51
What is the correct size front mount hydraulic pump for a TD-9 crawler?
Thanks,
Carl
rod
07-11-2004 09:35:09
 Re: Hydraulic pump for TD-9 in reply to Carl Matson, 07-09-2004 14:50:51
i have a pump off a td9 good shape for $150.00 the dozer had a ten foot blade on it. located in ohio
Carl Matson
07-12-2004 16:10:27
 Re: Re: Hydraulic pump for TD-9 in reply to rod, 07-11-2004 09:35:09
Rod,
I'm interested in the pump. Is it a high volume pump? Any pictures? Dimension of attachments to chassis and crank? I have an 8' blade. Cylinders look to be around 6" diameter with 12" stoke.
Thanks,
Carl
rod
07-12-2004 20:09:21
 Re: Re: Re: Hydraulic pump for TD-9 in reply to Carl Matson, 07-12-2004 16:10:27
carl send me a email so ill have your email to send a pic
Carl Matson
07-13-2004 03:06:06
 Re: Re: Re: Re: Hydraulic pump for TD-9 in reply to rod , 07-12-2004 20:09:21
Rod,
I can't get into you e-mail address?
Carl
rod
07-14-2004 16:43:52
 Re: Re: Re: Re: Re: Hydraulic pump for TD-9 in reply to Carl Matson, 07-13-2004 03:06:06
give me a call 419-946-1569 leave a message if im not here. with your number rod
king of obsolete
07-09-2004 18:01:01
depends on the blade you are running, the BE blade uses a large volume pump but low pressure where as modern pumps use low volume and high pressure, check my web site or redpower and you might see what you need, thanks
www.kingofobsolete.ca
