Paul, A couple of things come to mind. First, I suspect you have a JD model 3315 winch. These are self contained with regard to a pump which actuates clutches to engage winch reel and also a piston which releases the brake. Be sure the cable (that runs from the control lever by the seat to the hydraulic valve under the seat) does not have much "slop" in the linkage. I have seen these get loose from their mountings (or out of adjustment) which results in too little travel of the control valve spool. When you pull the winch control lever back then it should allow the winch to "free spool". The lever should remain in this position due to a "detent" in the control valve. If the winch reels in cable ok when the lever is pushed forward (with the reverser in forward and foot ("clutch") released) but does not release cable to unwind when lever is pulled back, then I would suspect problem with control linkage. Second, it is possible that you have a Gearmatic model 9 or similar winch and this is a completely different matter that I will not go into here since I hope your have the John Deere type. Good luck and let us know of your progress.
