Engine oil level rises
Jim in Oregon
07-13-2004 19:19:16
I have a 350 JD deisel and after I changed the oil, in about a week the level rises about 1 qt above the full mark. After 2 weeks it's about two qts above. I can't see any water in the oil. Can anyone tell me where it might be coming from?
Thanks,
Jim
Morris
07-16-2004 19:33:42
 Re: Engine oil level rises in reply to Jim in Oregon, 07-13-2004 19:19:16
on your machine there is only 3 things that can cause the oil level to rise, water, fuel, and hyd. oil. water will turn the oil milky looking, fuel will thin the oil and leave a smell, hyd.oil dosent change the oil any ( no color change, no smell, and very little change in oil viscosity). if there is no fuel smell in your oil you have a shaft seal leak on the hyd. pump.
Jim in Oregon
07-18-2004 09:35:53
 Re: Re: Engine oil level rises in reply to Morris, 07-16-2004 19:33:42
Thanks to Morris for the information. Jim
barryinmn
07-14-2004 21:34:11
I rebuilt the IP & pinched a seal when going back together. Same fuel in crankcase as your seeing. You may need an IP rebuild & new seals. Seals alone were $10 at an ag JD dealer. You have to get a mirror & look under the shaft to be certain not to pinch the seals when going back together. The IP bottom attaching bolt is a real piece of work, be prepared to grind a box end wrench to fit.
Chip
07-14-2004 13:44:53
Does the oil have a fuel smell? 2qts,it should.Other posts are on.Transfer pump is easier to check,pull it off & look/smell for fuel in back of housing.
GLewis
07-14-2004 06:41:48
If your oil level is rising it can only be coming from one place. 350's do not have torque converters, there is a regular clutch in front of a directional reverser so oil could not reach the engine. Your injection pump seals are leaking and allowing fuel to run into the pan via the timing gear train. The injection pump mounts on a shaft attached to the timing gear. The pump has a hollow sleeve in the center that slides over the gear shaft that is fitted with two cup type seals. The hole in the pump is fitted with a brass sleeve that will wear in the area of the seals. Have it replaced before you install new seals or you will never stop the leak. The pump timing procedure on Deeres is easy but getting the seals in correctly is a real pain, buy the Deere seal installation tool for $10.00. Your leak is going to get quickly worse and you could ruin your engine if you run it under a load with a pan full of diesel.
Steve
07-14-2004 04:32:53
third party image
Wayne is correct with certain machines. However this is pretty much impossible with a 350 at least with the straight 350, the "B" or the "C". Maybe the later machines this was possible on. You probably have a leaky fuel pump. Could be either the transfer pump or the injection pump leaking fuel internally.
scott in wa.
07-14-2004 08:30:54
 Re: Re: Engine oil level rises in reply to Steve , 07-14-2004 04:32:53
Steve, I have a 440icd late model.
I would like to replace the hydraulic block that articulates the bucket, I believe its a three position lever, or replace all the seals and o rings.
Can you supply either?
How much?
Thanks
Scott in wa.
Wayne
07-13-2004 21:40:04
When the oil level in an engine is rising and there is no water present it has to becoming from one of two places. First check the transmission/torque converter oil level and see if it is going down. If that is the case then the rear main seal is leaking and the oil is getting into the engine from the torque converter housing which is at a higher pressure than what is in the crankcase. If that level isn't dropping keep a close eye on the hydraulic oil level. If there is a hydraulic pump being gear driven directly off the engine then the shaft seal in the pump is bad and leaking hydraulic oil into the engine that way. Hope this helps.
jas
07-14-2004 09:35:55
 Re: Re: Engine oil level rises in reply to Wayne, 07-13-2004 21:40:04
not sure on JD but if hydrolic pump bolts to auxilary drive on engine a leak there can cause the hyd. oil to get pushed into engine though the shaft
