Hercules GO-130 head gasket
Dianne
07-25-2001 08:05:18
Does anyone know where I can get a head gasket for a Hercules GO-130 (3 cylinder gas) engine? (Other than Zimmerman's for $80 each!)
gary OC-46
07-25-2001 14:48:19
 Re: Hercules GO-130 head gasket in reply to Dianne, 07-25-2001 08:05:18
Dianne, you might try the following. I see these ads in a construction trade paper( Rock and Dirt).
(1) Hercules engine parts. Current and obsolete 740-745-1475 or fax @ 740-745-2475.It says "give us a try" (2) M& M surplus sales @718-829-9026 or fax 2 718-828-9851 in Bronx NY.
I have NOT dealt with either one but I see there ads month after month. Lot's of luck.
When you did your motor did you re-use the old gasket ?
Dianne
07-26-2001 05:58:12
 Re: Re: Hercules GO-130 head gasket in reply to gary OC-46, 07-25-2001 14:48:19
The gasket was new but I have been chasing a coolant loss problem - combustion gases getting into the coolant passages - and had the head off a few weeks back to look for signs. I didn't find any signs of leakage but I put the head back on with gasket schellac to try to be extra sure of a good seal - it wont come off in one piece this time!
I still haven't been able to find the problem - still searching. There is a more in-dept discussion of the problem on the ACMOC board under "coolant loss".
