d6 8u clutch
Frank
07-23-2004 12:09:20
I had trouble with the rubber links recently that hook the clutch plate to the flywheel. That is all taken care of now. Now I'm having trouble with keeping the clutch engaged. It rattles the linkage and pops out. It's not slipping it just pops out. Any Ideas?
Bob/Ont
07-23-2004 18:01:31
 Re: d6 8u clutch in reply to Frank, 07-23-2004 12:09:20
Frank, you need to tighten up the clutch adjustment so the lever takes a 30 lb pull to snap it over center. Inside the housing cover you have to unlock the spider and turn it up a bit and re lock it when the pull is right.
Later Bob
