case D350 info/help
Tim
07-23-2004 19:09:32
I am looking at buying a Case D350 dozer. The serial number is 3050070. Could anyone help me determine the year? Could anyone shed some light on a hesitation when reversing? It engages after a few seconds and does not slip and only occurs when going into reverse and seems to be worse when hot.Is this something common to these machines or is it something to be concerned about? Any and all help would be greatly appreciated. Thanks Tim.
Windancer
07-26-2004 02:00:58
 Re: case D350 info/help in reply to Tim, 07-23-2004 19:09:32
My '74 bears S/N 3055441 so the one you are
looking at is a earlier '74 or maybe '73.
I don't know about the reverse shift lag.
Mine don't do that. Otherwise, I like the
Case 350. Watch for loose final drives.
If you can, jack up the rear to take the weight off the rear of the tracks and run a pry bar under each sprocket to see if any wobble is present. For more in-depth info, e-mail me at
windancer@wwnet.net (Monday July 26th)
