IHC 500E Final Drive
LFC
07-24-2004 19:20:26
I recently purchased a 500E dozer that apparently had been run with little oil in the RH final drive. The pinion bearings went, but the machine continued to be used until the pinion shaft broke through the final drive housing. The pinion shaft worn into the bearing seat, so repairs to the housing will be nearly impossible. I've searched the country for a used RH final drive (or at least even a housing), but have had no luck. Apart from buying a very expensive repro housing, does anyone have any ideas where I could find these parts? Thanks.
LFC
07-29-2004 17:14:49
 Re: IHC 500E Final Drive in reply to LFC, 07-24-2004 19:20:26
I am happy to report that I purchased a 500E RH final drive housing from Schaefer Enterprises - seemingly the only one in the country! Thanks to Ken and all others for the help. My old housing is not easily repairable since besides the cracked pieces, the pinion shaft wore well into the inner bearing seat area.
83Jim
07-27-2004 10:00:22
Industrial Casting and Gear may be able to repair your final drive housing.
Phone- 208-265-5868
Good luck.
Ken NE WI
07-25-2004 07:20:56
Call Construction Equipment Parts Co. 800-727-8787, WEB SITE www.ceparts.com. They have an ad stating they have 500E for salvage. If they don't have what you need, they can get on the HOT line to other dealers. Good Luck
LFC
07-27-2004 08:17:19
 Re: Re: IHC 500E Final Drive in reply to Ken NE WI, 07-25-2004 07:20:56
Thanks Ken. I called them, and while they do have a 500E, they have no final drive parts. I've also had a network search completed, but no luck so far.
JimInOz
07-28-2004 21:13:08
 Re: Re: Re: IHC 500E Final Drive in reply to LFC, 07-27-2004 08:17:19
I'm in Australia.I have 2 complete finals from a 500 loader,possibly an early model with reverser trans.
ozguy1@optusnet.com.au
Ken NE WI
07-27-2004 20:41:09
Schaefer Enterprises of Wolf Lake Inc. 800-626-6046, E-mail parts@sewlparts.com Their web site lists 500e, and 500c are dismantled. I don't know whether you can interchange the two, but they do share alot of common parts. Housing no's for 500e 852 623 C91 right, 852 622 C91 left
Ken NE WI
07-27-2004 20:07:45
Try Link for salvage yards. Another Crow Custom Cast Welding Hudson, WI 715-425-6653 E-mail crowcast@presenter.com Hope this helps.
