Cat D6 Low fuel pressure
Ossie
07-26-2004 19:49:56
Have a D6C and ran it out of fuel. Ok refueled, changed filters, bled the lines and started the engine. Runs good but will not build up fuel pressure and after approximately 20 min will starve out for fuel. Had this happen before and after several time of restarting and running the fuel pressure came back up and pegged the needle but not this time! Have run it for several hours now on different days and still can not the fuel pressure back up so that the engine continures to operate a full power and continously. Now at beginning it starts and runs great with full power. I have checked the fuel flow to the injector pump and is fine plenty of fuel getting there and the filter is new . Any help or little tricks will be greatly appricated.
Best regards
Ossie
Bob/Ont
07-26-2004 20:26:41
 Re: Cat D6 Low fuel pressure in reply to Ossie, 07-26-2004 19:49:56
OZ, you have some dirt under the fuel pressure relief valve. I need to know your serial# and can give exact advise on monday.
Later Bob
Ossie Smith
07-29-2004 19:01:43
 Re: Re: Cat D6 Low fuel pressure in reply to Bob/Ont, 07-26-2004 20:26:41
I GOT IT ... there is a small filter for the fuel made of brass the is just behind the fuel filter . It was stopped completely up ! Cleaned it throghly and now I have full fuel pressure again \. Thanks for the help everyone Ossie
Bob/Ont
07-29-2004 19:12:03
 Re: Re: Cat D6 Low fuel pressure in reply to Ossie Smith, 07-29-2004 19:01:43
That's good Ossie, you likely cleaned the tank out into it when you got so low on fuel. There is a large plug in the fuel transfer pump that has the relief valve behind it. If the pressure gets low again take out the plunger and make sure there is no dirt under the seat of it as well. There is a sediment drain on your fuel tank too, run a bit of fuel out of it every month or so and that will help too.
Later Bob
