cletrac bgs
dillon
07-27-2004 09:23:02
I might buy a cletrac bgs with a ware loader? It has been sitting in the woods for a number of years and I would like to get it running so I can drive it on a trailer if I buy it. My first ? is are carburetor kit available? Secound what brand and size spark plugs are recommended? Third what motor oil should be used? Fourth does the transmissions and final drives take 90wt? Fifth should lead additive be used in the gas? If I buy it and after I get it home I will have to change the right side final drive seal how hard of a job is this to do? Would napa have this seal? How do you adjust the steering brakes? One more ? does anyone have the u.c. measurements?
JerePa
07-28-2004 17:05:22
 Re: cletrac bgs in reply to dillon, 07-27-2004 09:23:02
Try Zimmerman Oliver, Cletrac @ 717-738-2573. Thats all he does-cletrac crawlers.
Bob
07-27-2004 18:52:33
The carb's are simple, if you clean it and make a new gasket it will likely run fine! Use AC plugs, Shell Rotella T 30 oil and non EP GL 1 90 wt gear oil in the Transmission, bevel gear housing and final drive which are all in one, with an oil circulation pump. Fill the trans and take the level plug out on the finals and with the engine running in neutral add oil slowly to the trans until it starts to come out of the final. The track should have 30 links per side. If only 29 one has been removed because the track are shot, and they are not made any more!! Good luck
moseed
07-27-2004 15:27:18
dillon,
Go to Cletrac.org. Blake is the fellow you want to talk to about Cletracs. Goodluck!
