OC 4 Hydraulics
Jed
08-02-2004 12:24:09
My OC 4 will blow oil out of the threads where
a hose nipple meets the control valve. I took it out and retaped it. It worked a little and then blew out again. The next time I put in a new nipple which I taped also. I next sealed the outside with JB weld. It worked for a little while , but again began blowing oil out around the threads. Any help would be appreciated?
RAB
08-02-2004 14:43:40
 Re: OC 4 Hydraulics in reply to Jed , 08-02-2004 12:24:09
Neither tape or JB Weld are designed to stand hydraulic system pressures. Sounds like you have the wrong fitting.
Regards, RAB
