TD14 steering problems
Jim O.
08-02-2004 19:45:56
I just recently purchased a TD14. The left steering clutch does not work. I was told the "pin was out of the steering clutch". I realize it may be a stuck clutch. If it was the "pin", is it hard to install and how? Is there any way to tell the difference between a missing "pin" and a stuck clutch? thanks.
pdmech
08-03-2004 04:48:45
 Re: TD14 steering problems in reply to Jim O., 08-02-2004 19:45:56
third party image
More than likley you"ll end up with it out. If you do, and you need parts, be sure to contact us. We have new steering discs available as well as other parts.
captain_crunch
08-02-2004 21:55:34
Come over to Red Power Mag Forum we can post pictures there. Only pin I can think of goes from the vertical clutch arm to the throw out bearing and as hard as they come out can't imagine it falling out. These machines are famous for the steel discs sticking to the fiber discs.
