Thanks Sid - I'd like to learn as much as I can. I've been studying the manuals and parts books, as well as talking to the folks at Twin Disc. Twin Disc tells me that the two converters have different torque ratings, with the TD-24 unit having less torque. The two units interchange physically behind the flywheel, but the performance would be less with the older converter. How much? I don't know. The parts to fix the TD-25 converter cost ~$700. I guess it boils down to how much do I want to spend versus how many times do I want to remove and install this unit from the machine? At this point, I'm leaning toward putting the TD-24 converter in the dozer just to get it back up and running (and making some money) while I gather up the seals for the correct converter. Swapping them out next time will be much quicker than this time was. If anyone has ever swapped out a manual shift tranny for a powershift, I'd sure like to hear about it - since I've located a new tranny for cheap. Plus, the torque converter for the powershift uses hydraulic fluid rather than fuel. Thanks to all for your help!
