742 bobcat thrown rod need replacement engine ford
randy daniels
08-07-2004 20:46:43
i need a long block for my bobcat skidsteer loader (742) it has a ford industrial 4 cylinder i98 cid and was told that a ford car engine would fit but you had to put a spacer in between the flywheel and crank, but i don't know which car engine that it would be?
Rich Herrmann
03-31-2005 08:55:04
 Re: 742 bobcat thrown rod need replacement engine in reply to randy daniels, 08-07-2004 20:46:43
Has anyone put a different engine, like a pinto engine in their Mustang? I have a 440 with a stuck Ford KSG416 98ci engine in it. I would like to get another engine or retrofit a different one but don't know what to do. I found a Ford VSG411 but don't know if it is any different. I appreciate any help.
chvet73
08-10-2004 14:32:29
I rebuilt that same engine in my 722 last year. It's essentially the same as a 1.6L Pinto engine. I got all my parts from a Ford Industrial engine dealer. I did replace the distributor, using a Pinto part that I got thru Napa. It fit and works fine. It's my understanding that some of the Industrial engine parts are supposed to be built heavier than the Pinto ones.
pg in pa
05-17-2005 14:47:35
 Re: 742 bobcat thrown rod need replacement engine in reply to chvet73, 08-10-2004 14:32:29
I just had a local machine shop rebuild an engine from a Bobcat 642. This is a Ford 1600c 98ci engine, model 2274E. They seemed to have little trouble getting engine parts, although an oil pump was a bit tricky. They stated that the engine shares parts from the Fiesta and Pinto engines, but it is really not either engine directly. Total cost was $1350. Good luck.
DaveInMI
08-09-2004 03:30:58
I have a 2.0 liter SOHC out of a Ford Pinto. You can contact me at daveinnmi at yahoo dot com if you think it might work for you.
Roger
08-08-2004 05:43:30
Where are you located? Do you know the model of your engine. I have some industrial 4 cylinder Ford engines. Roger
dale rennells
01-18-2005 11:04:12
 Re: 345 mustang skid steer thrown rod need replace in reply to Roger, 08-08-2004 05:43:30
Hi Roger,
I have a 345 skid steer with a thrown rod through the block.
model is 2274E
1.6 liter
serial # E4232-88
Build# l-0e0-000-y00-0004
Do you have the short block that would fit this?
thanks,
Dale
Randy
08-08-2004 16:53:29
 Re: 742 bobcat thrown rod need replacement engine in reply to Roger, 08-08-2004 05:43:30
The numbers on the engine are:
1.6 liter
fuel P RPM 1500-3600
hd pr
block hc
serial number and date: e0155-785ha
Build juno00v00000
Special equipment 5
Modle 2274e
I live in Missouri and my parents are in Florida on their way back here.
Thank you Roger My phone number is 660-565-2368.
Bus Driver
08-09-2004 18:28:11
 Re: 742 bobcat thrown rod need replacement engine in reply to Randy, 08-08-2004 16:53:29
This way out of any expertise I have, but the 1.6 litre was in the Fiesta if I remember correctly. If a wrecking yard near you has one of those, looking at it would confirm, or not, that it is the same basic engine.
Roger
08-08-2004 17:41:43
Randy I will try and get the numbers from my engines tomorrow. I am in Northern Ill. My e-mail is hayenga at rochelle dot net Roger
Roger
08-09-2004 11:40:04
 Re: 742 bobcat thrown rod need replacement engine in reply to Roger, 08-08-2004 17:41:43
My engines are 140 CID. Roger
