JD 510 SWING CYL
RJC
08-08-2004 06:47:34
Going to rebuild the swing cylinders on a 510 backhoe. Can't get the pins out of the cylinders to remove them. Anyone taken these out?
Chuck Hilton
08-09-2004 04:18:12
 Re: JD 510 SWING CYL in reply to RJC, 08-08-2004 06:47:34
I've always rebuilt the swing cylinders while stillin the machine. They will stay well supported while removing the packing nut and no fighting with the pins.
Jonathan in MA
08-08-2004 19:57:20
I remember 510's having alot of pins retained with those tapered bushings that are such a joy to remove...if this is the case...what tends to work to remove those tapered bushings is a multitude of strong blows to the side of the protruding part of the bushing with a large punch and sledge hammer...If you strike them from the side it tends to use the taper of the pin and bushing to force the bushing outward...
