JD 1010 sticking valve
Brian
08-08-2004 21:10:51
I have a JD 1010 gas that had a stuck valve this winter & again now. Only about 6 weeks since it last ran. Easy way to fix?
JD dozer mike
08-11-2004 12:06:44
 Re: JD 1010 sticking valve in reply to Brian, 08-08-2004 21:10:51
Take the valve cover off and lube the stuck valve stem from top. tap lightly with plastic hammer, work up and down untill smooth.
Check your oil flow, maybe have pluged capilary and not enough oil getting to valves.
you should be able to start engine with valve cover off to check for oil. just dont run it long that way, maybe 1 minute tops.
