Grease for backhoe pins bushings
Dennis/Ohio
08-10-2004 01:47:50
Hi,
Anybody have a grease for backhoe joints that they feel is the best. I've heard some crazy stories about using the wrong grease on some newer machines but this is an old Case hoe. I like Quaker State Golden Chassis Grease but Its no longer made. Thanks, Dennis.....
Scott Penna.
08-12-2004 13:05:26
 Re: Grease for backhoe pins bushings in reply to Dennis/Ohio, 08-10-2004 01:47:50
The name if the grease I use is "FUCHS" #2 poliplex, it is white in color. Seems to be doing a good job !!!!
JerePa
08-10-2004 19:21:56
Any good brand NLGI #2 EP grease is good. Drydene (now Castrol) had a "contractors grease" with graphite in it.
Jeffie
08-10-2004 17:48:13
I use this Chevron Red grease, high pressure,
sticks like baby snot.
I'd only worry about grease you are using, if you are under warranty.
Otherwise then get an use a high quality, high pressure grease.
Dennis/Ohio
08-10-2004 18:24:00
 Re: Grease for backhoe pins bushings in reply to Jeffie, 08-10-2004 17:48:13
Mines a Case, I prefer the grease leaking out is the same color as the tractor. Ha Ha... Actually the Golden grease looks pretty good till I run out.
Thanks, Dennis....
Dozerboss
08-10-2004 20:17:26
 Re: Grease for backhoe pins bushings in reply to Dennis/Ohio, 08-10-2004 18:24:00
Always did buy the best---moly. Moly is suppose to reduce wear. Rated for high temp like wheel bearings on disc brakes trucks, but it stays fluid at low temperatures.
