Hydraulic leaks at pipe thread fittings
Dennis/Ohio
08-12-2004 18:34:29
Hi,
Have a low pressure hydraulic pipe fitting that refuses to seal. Its OK for awhile but the leak has came back three times now. Tried pipe dope and teflon tape. Is a sealer available thats better for hydraulic oil? The seepage is slight but after 3 times I'm getting mad now....
Thanks, Dennis.....
jhill
08-14-2004 06:15:08
 Re: Hydraulic leaks at pipe thread fittings in reply to Dennis/Ohio, 08-12-2004 18:34:29
Try Loctite PST pipe sealent with teflon. Made to seal hydraulic fittings. Stays flexible so it can withstand vibration. Works great.
Hydraulic guru
08-13-2004 16:59:11
Be sure that both metals are the same, steel to steel---brass to brass, use teflon tape, be sure that the threads are really pipe threads, and not a SAE straight thread to NPT thread match, or I should say mismatch. Look for a crack in the fitting or valve housing, if it still leaks then try JB weld or devcon metal putty. If all else fails then get a new valve or filter or what ever it is that is leaking.
smky dave
08-14-2004 04:09:10
 Re: Hydraulic leaks at pipe thread fittings in reply to Hydraulic guru, 08-13-2004 16:59:11
if all else fails try so pipe dope called expando, you mix it with water then assemble pieces and let cure this always does the trick
Dennise
07-07-2006 11:00:31
 Re: EXPANDO Pipe Dopw in reply to smky dave, 08-14-2004 04:09:10
Who is the vendor for the EXPANDO Pipe Dope and do you have a phone number for the company?
Thank you! Dennise
dog
08-13-2004 13:25:00
ya might have a hairline crack in the filter housing if im understanding you correct.
Jed
08-13-2004 10:01:23
I had the same problem with a control valve on my OC 4. I tapped it and it still leaked. I replaced the nipple and tapped it and it still leaked. Next I removed it, tapped it and J B welded it and it still leaked. Talk about being agitated! I next removed the nipple and inserted a hydraulic hose in it's place. Problem solved until I through a track. OH well!!!!! !!!!!
Charlie
08-13-2004 05:34:17
This may be far out, but are you absolutely positive that both components are really pipe threads? One side could be designed for a different kind of seal. Two other possibilities I can think of are that one of the threads might be really warn, as from once being mated with other than a matching pipe thread, or there is some torque on the joint that is causing one component to turn.
Dennis/Ohio
08-13-2004 06:04:52
 Re: Hydraulic leaks at pipe thread fittings in reply to Charlie, 08-13-2004 05:34:17
Both are 3/4 pipe fittings I bought at a local hardware when I added a return oil filter. The fittings are probably not the best quality. I can"t see anything wrong with them but I wouldn"t be suprised if I bought fittings from a local hydraulic shop and ended the leak. The pressure is around 20psi.
Thanks, Dennis.....
Tommy D6-8U
08-12-2004 18:59:34
Dennis,
Loctite makes a product for hydraulic pipe fittings if you can find a distributor in your area for their products. Its kinda' red like threadlocker but its made for sealing threads.
Tommy
