International T D-6 crawler
Jerry Hertler
08-12-2004 22:06:09
Hello. My TD-6 starts on gas and then switches to Diesel. It runs good on gas after you switch to diesel it will run smooth and no exaust for 2 to 4 mins. then it will start to smoke and loose some power. I fixed all fuel leaks cleaned air filters and air intake. Bled air out of fuel lines anf filters. Cleaned the water trap. Nothing seems to help.I can not find anyone here that knows about the TD-6s.
I could use any halp that I can find.
Thank you very much Jerry
Geoff NY
08-16-2004 13:06:11
 Re: International T D-6 crawler in reply to Jerry Hertler, 08-12-2004 22:06:09
Didn't see that you put in new fuel filters? Also make sure that the linkage is right (switch over linkage has to work positively it's overcenter type) The fuel that was mentioned in the oil resovoir will eventually increase wear in the pump' but not effect running. Bleed everything again according to the manual, and make sure the govenor spring is free. Might want to clean the screen in the primary pump too. Usually they blow dark smoke for a while til they're hot. Maybe work it some. Good luck Geoff NY
king of obsolete
08-13-2004 20:35:39
come to red power and we post pictures and have lts of fun with the crunch family ---- Link -----thanks
Geoff NY
08-16-2004 12:55:06
 Re: International T D-6 crawler in reply to king of obsolete, 08-13-2004 20:35:39
Been following your replies for a while, was wondering why you won't actually answer a question?
D7RANDY
08-13-2004 05:11:19
DRAIN OIL OUT OF INJECTION PUMP REFILL CLEAN OIL PUMP MIGHT BE FULL OF DIESEL
