no brakes on the Dynahoe
Andrew
08-16-2004 14:12:43
I have a dynahoe model C that has no brakes. I checked the master cylinders and found them dry. I took them off and it seems they are stuck. If I put brake fluid in them I can't bench bleed them since the piece you push in to make the brakes work is stuck. Anyone have any tricks to unstick master cylinders? Or would anyone know where to get new or rebuilt cylinders? These are from Lockheed Wagner and have a FE-17905 number cast in the side.
drdsl
08-16-2004 18:35:09
 Re: no brakes on the Dynahoe in reply to Andrew, 08-16-2004 14:12:43
Our local NAPA has some people who are very good at looking up these old brake parts provided you have the cast #"s, which you do. Try that, next try a construction supply ($) that sells komatsu/dresser. There also many companies out there now who resleeve master and slave cylinders for antique cars using brass or stainless. Check some antique car sites. Good luck.
Andrew
08-17-2004 06:08:30
 Re: no brakes on the Dynahoe in reply to drdsl, 08-16-2004 18:35:09
Great suggestions! Thanks for the help.
