JD350 oil pressure
PhilMac
08-18-2004 14:18:18
I have a JD350 and when started cold, the oil pressure is 60+. After it warms up the pressure drops to around 20.
What is the problem?
Thanks
Roy
08-21-2004 22:05:41
 Re: JD350 oil pressure in reply to PhilMac, 08-18-2004 14:18:18
Are you using multi-grade oil ?? I 've run into a problem with some multi-grade oils breaking down causing low oil presure at warm-up.. Try switching to straight weight SAE 30. It might surprise you
PD Mechanical
08-20-2004 05:35:34
third party image
If its 20lbs. at idle, probably nothing. When oil warms you will lose some pressure. Should be around 40lbs. +/- at operating speed when warm. If not then you may have some worn brgs. Probably mains.
