Cat grader
Hogman
07-29-2001 19:59:25
Just bought at auction a Cat 12 vintage of about 51. Has bearing out on left drive axle . How much should the old machine weigh ? can the bearing be changed without pulling the tandom unit off? was I super crazy to buy it???? Am about as knowledgeable on it as a sycamore fence post,realy need help.
ROD
08-17-2001 09:27:39
 Re: Cat grader in reply to Hogman, 07-29-2001 19:59:25
POST A PICTURE. MY GRANDFATHER USED TO HAVE A 8T. I WOULD LIKE TO SEE A PICTURE SINCE HIS HAS BEEN GONE FOR SEVERAL YEARS. I WOULD LIKE TO BUY ONE. HOW MUCH DID YOU PAY FOR THIS ONE? THANKS.
greg
08-09-2001 19:06:42
Seems this machine, if it is a 212, was around 13,000# plus a little, if my memory serves me well from manuals i used when I had a real job.
Hogman
08-10-2001 14:53:00
 Re: Re: Cat grader in reply to greg, 08-09-2001 19:06:42
Thanks alot Greg,had about given up on any reply.Since My post I checked with CAT about a book on it. Cost was about $235 ,man suggested the money would be better spent hiring a heavy equipment mechanic,just last night think I have found one. It's an 8T ## and parts are still available which is Good.Guess the old CATs are kinda like Ford N's.
Thanks again
greg
08-05-2001 18:58:18
51 vintage should be a model 212. If it is, need to pull covers on tandem housing, disconnect chain, then remove wheel, tire, stub shaft retainers, etc. Wheel hub can be real tough to get off.
