JD PTO, powershaft parts-winch
LD
08-24-2004 06:25:17
Looking for the pto handle/lever and parts inside the clutch housing for JD 450B with HLR tranny. Maybe the powershaft too. Don't know until teardown. Anyone know possible sources? Has anyone had a pto failure and put it back together without pto? What clutch housing parts would you remove to avoid collision problems with pressure plate? Tried looking through rubber plug on housing but can't see if parts below handle are intact. Thanks.
Jim in michigan
09-04-2004 19:32:23
 Re: JD PTO, powershaft parts-winch in reply to LD, 08-24-2004 06:25:17
if you are looking for a used winch I have one for sale,,,,Jim
PD Mechanical
08-25-2004 04:50:33
third party image
LD: The pto drive gear and fork (if it has the fork) are not loacted in the clutch housing itself. They are located behind the reverser front cover. So you won"t be able to see anything through the rubber plug anyway. Once engine and clutch housing are removed you"ll have to remove front cover of reverser to access pto drive gear. Also, the pto shaft should come out the rear of the machine just by removing the retainer at the rear.
Mark/
08-24-2004 08:49:21
LD,
There is an outfit in Oregon, near Portland I think - that deals in winches for Deere. I've never delt with them, nor have I ever contacted them. I'll look around for a little more info. Perhaps someone else may know of this place.
Ld
08-24-2004 17:43:27
 Re: JD PTO, powershaft parts-winch in reply to Mark/, 08-24-2004 08:49:21
Thanks, someone told me the winch equipped machines don't have the floor pto lever. Meaning the pto shaft always turns but doesn't power the winch until you move the winch control cable. Winch doesn't work on this machine and pto shaft doesn't turn. Appreciate whatever info you can findout.
