L ow Pressure grease gun for JD rolls
CPeter
08-24-2004 18:37:50
Where does one get one of these creatures? And how much?
CPeter
Lavoy
08-25-2004 07:46:56
 Re: L ow Pressure grease gun for JD rolls in reply to CPeter, 08-24-2004 18:37:50
I have the number someplace, I believe it is a 1013 Lincoln.
Lavoy
Dozerboss
08-24-2004 23:38:05
For a 450:
I replaced my gun when it failed, with an angle gun from walmart. You can use a regular grease gun rated up to 8000 psi to adjust track tension. But i didn't find the actual rating for the special roller gun. I found 2 guns at walmart rated lower--6000 psi max if i remember correct and use it with no problems. You apply grease slowly to rollers until resistance is felt. I will look and see if the brand is on the new gun and psi on the broken gun if you want. I'm not sure if your 40C rollers need a lower psi than the 450. The angle guns have lower ratings than the straight ones.
