Galion Grader
HayBoy
08-25-2004 19:12:15
A friend of mine recently bought a Galion grader for his farm.Called and said it has a small tapping sound in the motor- not a hard knock just a light tick. I don,t know type of motor yet he just said the number on the motor is D359T.Anyone have any ideas on the make before I go look at it? Thanks.
1566 jim
08-29-2004 18:59:58
 Re: Galion Grader in reply to HayBoy, 08-25-2004 19:12:15
The d359t engine is a cummins 6 cyl B series engine. Run the valve you will probally find they are getting loose.
hig
08-26-2004 16:01:00
i believe that is an ih engine
Deas Plant
08-29-2004 00:02:31
 Re: Galion Grader in reply to hig, 08-26-2004 16:01:00
Hi, HayBoy. It is pretty certain to be an IH motor and I'd check that the rocker/tappet clearances are correct and then I think I'd look for a bent push rod.
Hope this helps.
You have a wonderful day. Best wishes. Deas Plant.
