4500 air in hydraulic
F4500
08-27-2004 03:29:49
I have a problem in Ford 4500. Sometimes it works well after I start digging. But sometimes, after a minute, its get air and pump starts whining. If I stop the engine and wait couple hours, it works well. But next day it could work or not. What could be the place where the air goes to reservoir?
Thanks and greetings from Europe!
Heat Houser
08-30-2004 23:27:40
 Re: 4500 air in hydraulic in reply to F4500, 08-27-2004 03:29:49
Had a pump with a worn shaft seal do as you describe. Also had pumps with a suction side leak that aerated the oil. I typically use foam type shaving cream sprayed around the joints to find a suction leak. Look closely and you will see a small spot of shaveing cream being sucked in.
Ford 4500
08-31-2004 22:34:15
 Re: 4500 air in hydraulic in reply to Heat Houser, 08-30-2004 23:27:40
Thanks for a great tip!
If it is a worn seal, is it hard to change? Do I need any special tools?
