oliver dg bg ?
d
08-31-2004 19:46:38
Do the old oliver dg's or bg's have any major proublems.
DGH
08-31-2004 20:54:55
 Re: oliver dg bg ? in reply to d, 08-31-2004 19:46:38
No! Just that parts are hard to find!
D
09-01-2004 06:54:48
 Re: oliver dg bg ? in reply to DGH, 08-31-2004 20:54:55
How is there steering? Some people have told me that it is air? Insted of hyds?
DGH
09-01-2004 21:18:11
 Re: oliver dg bg ? in reply to D, 09-01-2004 06:54:48
All DG and B models had manual steering. The air assist did not start until the OC series and then only on the OC 15 and 18. Keep the steering brakes properly adjusted and extend the levers and they are not to bad to steering, but you do get a workout!
george md
09-01-2004 20:25:56
D,
Some of the later ones had air assist on the
steering brakes . Other post is correct ,
cletrac used controlled differential and
steering is by slowing one side and that speeds
the other side .
george
F100Panel
09-01-2004 15:37:31
No real steering "clutches"... The machines have a rear differential with a band brake on each side for steering. Gotta REALLY pull on the levers to make"em turn... Guess these machines were built back in the days when men were MEN.. Runn"in one of"em for a few hours will really give ya a workout. On the bright side- no steering clutches to freeze/rust up from sitting.....
Dianne
09-20-2004 03:17:21
 Re: oliver dg bg ? in reply to F100Panel, 09-01-2004 15:37:31
"Guess these machines were built back in the days when men were MEN.."
Oh oh! Guess I'm in trouble!
The band steering isn't that bad but band condition and adjustment makes a big difference. Mine needs new brake linings - turns one way are a snap, the other way is a two-hander!
