Poclain 400
bowed
09-02-2004 02:01:24
The tracks and turret motors seems to be locked on a hydraulic safety. I did notice the hydraulic oil level was low and filled the tank. How do you release the lock. Everything else is operating fine. There is pressure in/out on the motor lines.
hig
09-03-2004 15:27:56
 Re: Poclain 400 in reply to bowed, 09-02-2004 02:01:24
had a gck120 yard+one quarter excavator 70s vintage with drum brakes on swing + travel motors.small hyd.cyl.controlled each brake.levers under seat activated brakes.i recall that a spring applied brakes and hyd.pressure released them.
bowed
09-03-2004 05:30:30
I have check the cab and there is no turret lock. There is a lock for all hydraulics which is working. This problem I think must be an internal sensor or hydraulic safety?
Joel Harman
09-02-2004 11:29:27
Don't have 1 but look for lever in cab. will prolly be near back of cab if there is one.
Have 417-U Poor & Helpless. It has swing brake lever thru the floor
