Hole in block.
Broke
09-02-2004 09:20:37
Case 188
Connecting rod came looose on one side and punched a hole in the block near the fuel filters.
I have been told that sometimes these engines can have a patch welded on the block. Is this possible in your opinion? It is a flat spot where the damage occured. The hole is about 2" round.
Dennis/Ohio
09-04-2004 05:53:12
 Re: Hole in block. in reply to Broke, 09-02-2004 09:20:37
I would drill a small hole at ends of cracks, if any.
A weld shop in the area specializes in such welding. They put the block in a bed of sand and preheat it in a oven. After the welding its back into the oven to cool slowly. Quick cooling of cast iron after a weld is what causes cracks to run wild. If one guy worked a torch while the other guy welded with Ni-rod. Seems that might be a home brew worth trying?
Best, Dennis....
Broke
09-04-2004 09:36:13
 Re: Hole in block. in reply to Dennis/Ohio, 09-04-2004 05:53:12
Thanks Dennis. Makes sense.
jim/pa
09-02-2004 17:11:16
if there are no radiating cracks, and the block is still sound otherwise, its a piece of cake. it can be welded, silver soldered, or brazed. i've done all 3 in different circumstances. i would even think jb weld would work just to seal the hole.
Smilie
09-21-2004 20:17:34
 Re: Hole in block. in reply to jim/pa, 09-02-2004 17:11:16
This repair can definitely be done. I've been running a case 310g/188 with the exact same repair having been done by the previous owner. It has lasted three years and still going. Good luck
Broke
09-03-2004 06:39:30
Thank you Jim.
