580k
d. schrems
09-04-2004 03:43:29
i was recently using the clam bucket a my backhoe and i noticed a very load noise coming from the right dide hinge . it appears that the pin or bushing is worn causing the bucket to bind on the housing. any ideas as to what is required to take this apart would be helpful.
Mickey
09-05-2004 13:57:43
 Re: 580k in reply to d. schrems, 09-04-2004 03:43:29
I take it when you say clam bucket you are talking about the front 4 in 1 loader bucket,each of the hinges has a greasing point and should be greased regular,there is two bushes in each hinge and one pin,the pin is secured by a long bolt, first grease the hinges as they maybe dry,if there is too much play the pin and bushes may need changing.
