Clutch discs for steering allis chambler H3 crawler
ROBERT WELLS
08-02-2001 17:47:52
where can i buy discs and pressure plate for the steering
H-3 Fan
08-02-2001 19:35:06
 Re: clutch discs for steering allis chambler H3 crawler in reply to ROBERT WELLS, 08-02-2001 17:47:52
Robert you can try an old Allis Dearler they can get some parts through Minnpar. Minnpar bought up all the parts for the heavy equipment division form Allis when then went out of business. You can't buy direct from Minnpar unless you can run it through a business. Some things you can get and some you can't. Also hold you butt real tight, because they ask what ever they want for parts and nothing is cheap.
H-3 Fan
08-02-2001 19:34:21
robert wells
08-06-2001 18:17:52
 Re: Re: clutch discs for steering allis chambler H3 crawler in reply to H-3 Fan, 08-02-2001 19:34:21
well h_3 fan i found the clutches in chattanooga tenn. i need 8 clutches at $35.00 each and 3 metal bands at $50 each.andthen ive got to have the preasure plate rebult at $100 each. i have no choice becouse i ve already got $1400.00 in the motor and i give $1000.00 for it. i think im loosing robert
H-3 Fan
08-08-2001 19:12:02
 Re: Re: Re: clutch discs for steering allis chambler H3 crawler in reply to robert wells, 08-06-2001 18:17:52
Robert I know what your saying. I'm redoing the whole undercarriage with new everything. The only saving grace is that I'm making almost everything myself(pins, bushing, axles, bearings and the list goes on). As I said before I've already done the motor. But they really are a great machine once you get them fixed up. Did you have a G-149 or the G-160 engine? Keep your chin up it will be worth it when you get it done. H-3 Fan
ROBERT WELLS
08-09-2001 12:54:26
 Re: Re: Re: Re: clutch discs for steering allis chambler H3 crawler in reply to H-3 Fan, 08-08-2001 19:12:02
there was a 160 in it but i cant find one so i was looking around and found a regular B motor and rebult it. i am runing it off of propane but i am stil trying to find a 160.i got all my parts so i going out to put it together i'll let you know how it comes out robert
