CJ
09-09-2004 09:01:47
Re: JD 350C hydraulics for JD 9550 backhoe in reply to JM, 09-08-2004 19:25:40
Seen acouple ways. If I remember right Deere plumbed them inline.Not sure if it was the supply or return of dozer valve-check w/Deere-it was factory/dealer setup.2 hoses w/couplers.You got close to hoe,shut off machine,anytime it ran the hose is 'live',unhooked hose's from each other,hooked to attacment,restarted machine.If you forget to hook hoses back together machine wouldn't start(hydraulic lock).This way hoe and blade work all the time,easier to move.The other way is a selector/divider. But when you want to move you have to keep changing selector.You want to use blade for stability,along w/hoe stabs.It was common to switch pumps,if there was one that would fit.you'll have to research a little maybe,but I'm thinking the loader version will go on the dozer &its bigger (gpm).Don't worry about counterweight,thats what stabs are for.MrBill is right, its hard on drives/tracks.Don't turn hard or doze w/hoe.You'll find it very hard to control,do decent work anyway.Do all the digging,get rid of hoe,use dozer.BTDT,its a PITA.Easier to remove hoe,after a couple times it'll get quick & easy.
