Yesterday I got my loader stuck in the mud. I backed into a soft spot in a low lying culvert area where the left side of my loader sunk into mud and settled in until it was buried up to the frame. The loader was then stuck, tilted at about a 25 deg angle to left. One thing I noticed when I was trying to get out was that the power did not appear to be fully transmitted to the tracks. The motor seemed to be running free with little or no load, the tracks would either barely move or not at all, and the transmission pressure sometimes would fluctuate a bit but then rise back to its normal (green) level. The tranny oil level has always been normal (I check it often), I just checked both the suction filter and the safety filter (both clean other than a few little clutch pack particles, which I assume is normal?) a few days ago and replaced the transmission cartridge filter about a month ago. The machine will normally dig into hard pack clay and push hard. Usually there is no problem with a slipping tranny etc.So today I added another gallon to the transmission before giving it another try. I thought it might help to get more oil to the oil pump. After starting the loader and putting it in gear I noticed that the tranny oil pressure did not fluctuate as much, mostly staying in the green if the motor was revved up a bit. So the extra oil did seem to help some. But then after putting it in gear, same problem, still no appreciable torque transfer to the tracks. The motor seemed to run free with no load to it. But then after really letting it warm up for a bit and struggling with it trying to go back and forth, I noticed that the engine started to take more of a load and the tracks were starting to move more. As I continued to struggle like that I noticed the trans oil temp started going up considerably. Once it got to 240 deg F or so (normally it runs about 200-210, same temp as engine coolant), there was definitely much more power transfer to the tracks. Apparently when the oil temp goes up it either increases the friction in the clutch pack and/or it thins to the point where the converter starts working more effectively. This is where I have a question. I've seen lots of other posts over the past year where someone has a problem with their powershift machine that is similar to this. Where there is no power transfer at first (or under certain circumstances) but then as things get going suddenly everything starts working properly and there is good power transfer. Do any of you experts know why this stuff happens? Is it the clutch pack finally getting enough friction together as oil temp goes up, or is it that the converter prefers thinner, hotter oil to really start transferring torque properly? Oh and by the way, once my machine started moving and getting leveled out (after me doing some shoveling under the tracks), it crawled right out of that mess and ran strong thereafter. Thanks in advance...
