clips for press.plate JD350B
jtinVA
09-16-2004 06:24:04
Urgently need pressure plate clips for pressure plate on right side (should be the same for either side) Have everything ready to reinstall clutches then realize that these clips are missing from right side.
I understand that these clips actually pull the disks away from the drum so that the disks aren't just slipping when you pull back on the steering lever.
Will take used or whatever you have.
I need also part T15831 which is a shield that goes under the right final drive for a JD350B if anyone has a used one. It may be called an inner sprocket shield or such. Just curves under the vinal drive like and extra guard for it.
Lavoy
09-16-2004 08:06:36
 Re: clips for press.plate JD350B in reply to jtinVA, 09-16-2004 06:24:04
Most of the pressure plates I have seen do not have these clips, and the ones I get that do, I take off and throw away. The one time I left them on, they all got knocked off on the first rotation.
Lavoy
