JD 450 transmission fluid
motorhead460
09-19-2004 18:56:19
I just purchased a 450 Deere (1970-?)and need to find out how and where to check the trans fluid and what type fluid it requires.I am new to dozers and have no idea where to check it or how.Also was wondering how I can tell exactly what model and year it is? I found the area where the ID# plate was at but it looks like it has been knocked off and lost years ago.Is there any other way to check block,final drive or other part numbers or something to tell what it is? Thanks for any help.Rick
rick roberts
09-20-2004 19:35:32
 Re: JD 450 transmission fluid in reply to motorhead460, 09-19-2004 18:56:19
Use Hy-guard tractor fluid- the dipstick is under the seat pad. Unscrew the cap,remove it, clean and replace , but do not screw it back down in order to check the level. You can fill thru the same opening
rick
450 -c
motorhead460
09-20-2004 20:22:24
 Re: JD 450 transmission fluid in reply to rick roberts, 09-20-2004 19:35:32
Thanks Rick,I found it just like you said.
