How to shorten JD 420C chains
Mike
08-06-2001 18:47:57
I have a set of chains for a 5 roller 420c and want to remove several links to use them on a 4 roller machine. I don't have access to a track press to press the pins out. Is it possible to remove the pins without a press? What is the best way.
Thanks,
Mike
Half Track
08-07-2001 05:41:04
 Re: How to shorten JD 420C chains in reply to Mike, 08-06-2001 18:47:57
Mike the answer is yes. Do you have a torch? It's easy, your rail should be the flush type. One way is to put rail on its side & try to drive the pin out at the joint you need. If that doesn't work cut the one link in two & slice the pin boss part of the link away from the pin & pull the other side out. Good Luck HT
