Case 1150 Dozer
Campellone
09-21-2004 13:08:10
Does anyone Know the timing degree mark BTDC or ATDC for inserting the feul injection pump to the engine? It"s a 6 cylinder I believe 401 diesel Thanks!
george md
09-21-2004 18:32:47
 Re: Case 1150 Dozer in reply to Campellone, 09-21-2004 13:08:10
Campellone, Plain 1150 with A401D sets at 31 deg BTDC , later ones with 401BD set at different number.
george
Campellone
09-22-2004 14:46:25
 Re: Case 1150 Dozer in reply to george md, 09-21-2004 18:32:47
George, Thanks a million for that info. I have inserted the pump a dozen times in hopes of getting lucky but to no avail. I'll try it tomorrow. Someone also said that I have to port time the pump. Have no clue what that means, I just hope it statrs with that info. Again thanks alot!
Peter
george md
09-22-2004 17:58:44
 Re: Case 1150 Dozer in reply to Campellone, 09-22-2004 14:46:25
Peter,
The pump drive gear has a mark and the housing behind the gear also has a mark,those must be lined up at the same time that the crank pulley is on the timing dimension. And you must also be on compression stroke not on the exhaust stroke . If you don't win send me a phone # .
george
Campellone
09-23-2004 16:38:14
 Re: Case 1150 Dozer in reply to george md, 09-22-2004 17:58:44
George, It worked beautifully. The machine is finally up and running. Sounds Great except for the psst, psst,sound of number 5 head gasket leaking. You wouldn't happen to Know the torque spec for the head bolts? I really appreciate the info on the timing mark. None of the local Case dealers wanted to bother with me because the machine is old and wanted Big $ to fix it themselves, so they opted not to give me the info. Thanks again. Wouldn't have been able to do it without you.
peter
george md
09-23-2004 20:44:42
 Re: Case 1150 Dozer in reply to Campellone, 09-23-2004 16:38:14
Peter,
Head bolt torque 145 to 150 ft/lbs
george
stevieandsam
09-21-2004 18:23:35
got a 1150B shop manual. "It says to crank the engine CW to 35 degree mark, then crank engine cw to specified fuel pump timing. Refer to engine data decal on engine valve cover for fuel pump timing." I actually had one of these machines and I replaced the fuel injection pump once a few years ago. I know that this isn't a lot of help, but I just don't remember it being that hard. I remember the gear on the front of the pump with a clear mark as to where it matched up with the internal engine gear, and there is a bolt on top of the gear cover that you can remove and see the timing marks that align the gear with the pump housing by loosening the pump mounting bolts and twisting the whole pump to align the marks. If i can look anything else up for you just ask
Campellone
09-22-2004 14:42:48
 Re: Case 1150 Dozer in reply to stevieandsam, 09-21-2004 18:23:35
Thanks alot Steve. I just didn't have a clue as to what the degree was. You are right in that the pump has timing marks. If it doesn't work I'll write you back. Thanks again,
Peter
