case crawler refit?
mud
09-22-2004 12:15:30
wondering if anyone here knows if another manufactuers engine will fit into an case 450 frame? perkins maybe?
i read about refits with other machines, but so far have not seen anything done with this machine.
curious if anyone here has done one or heard of one done.
thanks-
mud
Jack in Fla
09-23-2004 07:49:04
 Re: case crawler refit? in reply to mud, 09-22-2004 12:15:30
Hello, can you patch the hole? My dad did one time and rebuilt the motor and never had any problems with it. He used a copper plate and sealed it and put the nuts on the out side, The car was an Old Hudson Hornet with two two barrels on it . It would run, The company I work for has welded many patches on those old D-9 Cats. My 2cents worth. Jack
mud
09-23-2004 07:52:19
 Re: case crawler refit? in reply to Jack in Fla, 09-23-2004 07:49:04
that is an idea. i just wonder what kind of other damage has occured to the block when the rod turned loose. i reckon i'll neeed a machine shop to look it over good.
i bet that hornet was thirsty too!
george md
09-22-2004 18:06:20
Mud,
The later 450's had the consolidated diesel from the factory , Don't knowhow much blacksmithing
it would take to install one. I guess the question is 'why' , as the 188 or in later models the 207 is a great engine for
that tractor . It has plenty of power to spin the
tracks with a blade full or even while prying on
a stump.
george
mud
09-23-2004 07:41:46
 Re: case crawler refit? in reply to george md, 09-22-2004 18:06:20
my block has a hole in it the size of my fist. to the right of the fuel filters. connecting rod came loose and poked its head out there. i would like to replace it with a 188 or 207 but have not been able to find a compatable one. seems like those 188's where built a little differant for the ag tractors. all the industrial 188 engines i find are tall dollars. that made me get to thinkin about looking at another engine.
i like that 188. seems as though they are scarce and pricey though. fellers want more for them than i paid for the machine 10 years ago.
jim/pa
09-22-2004 14:30:13
with a little imagination you can always make something fit. it may not be ideal, but it may save a piece of equipment and not bust the budget. for tools to use in the refit, i recommend a cutting torch, and a feeler gauge.
mud
09-23-2004 07:45:35
 Re: case crawler refit? in reply to jim/pa, 09-22-2004 14:30:13
i agree that it may not be ideal. thats been my worry with the idea. i can't afford what they want for a running 188. i been looking for a year now. maybe its time to look at other engines and start measuring.
